Date/Time: Sun, 12 Jan 2025 00:52:53 +0000
Bid Ask Volume Delta
View Count: 1569
[2017-01-25 01:09:26] |
User731667 - Posts: 8 |
Hi just wanted to get some information on a particular chart I have come across in the Sierra Chart Package. The chart is in the BidAsk Volume Delta (Numbers Bars) Analysis Chartbook (preloaded on Sierra). 3 charts come up when you open the chart book, I have attached a picture of the chart I am particularly interested in but cant seem to understand all the numbers and the colours. What do the following numbers and colour combinations correspond to: Red Number / Green Number Red Number / White Number White Number / White Number White Number / Red Number White Number / Green Number Also is there anyway to change the block colour from Green to Blue? Have tried all the chart graphic settings but no luck. Thanks |
vol delt bar.PNG / V - Attached On 2017-01-25 01:08:19 UTC - Size: 63.86 KB - 470 views |
[2017-01-25 05:25:04] |
You need to understand how the Numbers Bars study works. Here is the documentation for it: Numbers Bars The study is highly configurable and what you see depends upon the study Input settings which are documented here: Numbers Bars: Input Settings for Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
