Date/Time: Sun, 12 Jan 2025 01:01:53 +0000
running two separate sierra chart account, each on a separate computer using separate feed
View Count: 757
[2017-01-24 18:34:57]
User424176 - Posts: 7
I'm currently running a copy of sierra chart in one pc using iqfeed as my data-feed, the account is not connected to any broker, it is just for testing my strategies.
I would like to run another (extra) new copy of sierra chart and pay the extra $20 that cost another copy on another computer and link it to an existing real trading account that will use Rithmic as the data feed.
Do I have to request the new account using a different email or can I use my regular email?
Please advise.
thanks.
Daniel
[2017-01-24 18:51:08]
You just log into the second copy of Sierra Chart using your same Sierra Chart account and there is no additional cost for this.
[2017-01-24 19:16:58]
would you please explain how to purchase another sierra chart "copy" or account?
thanks
daniel
[2017-01-24 19:35:53]
You do not need the other account and we do not recommend that.
If you need to use Sierra Chart on more than two systems, you can and we can give you instructions for that.
If you did want to create another account, that can be done here:
https://www.sierrachart.com/RegisterStep1.php
