Date/Time: Sun, 12 Jan 2025 00:49:05 +0000
[User Discussion] - Bug with renko and OHLC values?
View Count: 1345
[2017-01-24 16:02:43]
User560062 - Posts: 100
Hi
When I try to use renkos and use an OHLC study on top of it, the real 30 MIN OHLC (based on a separate 30 min chart) is not in line with what the renko chart shows. Shouldn't the study show the correct OHLC?
I need to match the renko open with the 30 min open but I cannot do so since they are all the time different.
Thank you
[2017-01-24 17:36:06]
Refer to:
http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#RenkoOHLCValues
[2017-01-24 17:55:16]
Yes I've read that before I posted which told me this might be a bug because the open price should be the same as 30 min timeframe and it isn't.. IE they should get the open and closes from the actual data which should be the same irrispective of timeframe. I am not referring to the Renko open.. this is from your documebtation:
Renko bars maintain the actual Open and Close values from the underlying price data for each Renko bar in addition to the Renko Open and Renko Close values.
