Date/Time: Sun, 12 Jan 2025 00:43:58 +0000
Current Price Minus Open of Chart
View Count: 1026
[2017-01-24 14:47:07] |
infpz - Posts: 826 |
Looking for a way to calculate the net change from the opening price of the 1st bar in the chart (I have 365 days displayed) until the last trade (current price). Ultimately, I am looking to compare this result to same result of another chart. Any suggestions? |
[2017-01-24 17:38:28] |
The closest is the Percent Change Since Open study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s325 We could create another study to calculate the actual change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-24 17:39:36] |
I would be interested in a "change from X bars ago" study or something similar.
[2017-01-24 18:06:02] |
This can be done by using the Bar Difference study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s56 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-24 18:10:46] |
Can I use a higher value than 100 for the Input Data 2 offset field?
[2017-01-24 18:23:07] |
Yes we will remove that restriction in the next release.
