Date/Time: Sun, 12 Jan 2025 00:58:27 +0000
What Does "Array is unallocated" mean?
View Count: 1525
[2017-01-23 17:09:36] |
User27189 - Posts: 26 |
[2017-01-23 17:28:07] |
This should not normally occur. It means a study array is being accessed but it contains no data. For us to resolve this, we need to get the Chartbook that is causing this. Here are instructions to attach it: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-25 00:59:03] |
User68474 - Posts: 201 |
Thank you.
[2017-01-25 06:45:20] |
We have determined the reason for the problem and it will be resolved in the next release. It is because you are using the Point and Figure XO Graph Draw Type but the Bar Period Type is not set to Point and Figure Bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
