Date/Time: Thu, 16 Jan 2025 17:19:45 +0000
Attached orders
View Count: 943
[2017-01-23 14:29:10] |
I - Posts: 6 |
I use rithmic data and I want to use attached orders simply because it should be easier when trading with more than one contract at a time. This quote from the information on bracket orders leaves me a bit unsure of the best way to proceed. "The sending of the orders to the exchange, the canceling of them, and Quantity adjustment of the orders is handled completely by the Trading service and not Sierra Chart. It is for this reason why it is not always advantageous to use server-side Bracket orders because the management of those orders is not always going to be correct or reliable based upon feedback from the field." Possibly rithmic was not referenced in this quote, not sure. I could always not select "use server side oco and brackets" if this would be more reliable. I look forward to your advice as to how to proceed. I am very pleased with your product. Thanks in advance |
[2017-01-23 18:14:50] |
Server side 3 order Bracket orders are not supported with Rithmic. Only server-side OCO orders. In the case of Rithmic we recommend using the option Use Server-Side OCO and Bracket Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-15 14:55:11] |
I - Posts: 6 |
I am unable to click on the support scale in button...I cant find it...sorry if its a stupid question enable Scale Out functionality, select Trade >> Open Trade Window for Chart. On the Main or C tabs press the Menu/M button and make sure there is a checkmark by Support Scale Out |
[2017-11-15 19:31:01] |
There are screen images here showing these particular menu command options: Attached Orders: Scaling Out Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
