Date/Time: Fri, 20 Sep 2024 23:50:17 +0000
[User Discussion] - Triangles
View Count: 1443
[2013-08-07 21:27:01] |
infpz - Posts: 826 |
Is there a triangle tool available that functions similiar to rectangle tool?
[2013-08-07 22:10:55] |
Not exactly. But they could use the Marker tool to put a triangle on the chart.
[2013-08-08 03:48:17] |
StevieD - Posts: 39 |
The zig-zag tool can be used to draw a triangle.
