Date/Time: Sun, 12 Jan 2025 00:40:27 +0000
ACS - trading APIs
View Count: 747
[2017-01-23 08:42:52] |
jizzary - Posts: 177 |
1. can u pls direct me trading APIs documentation page ? (hope it supports enquiring APIs to find commands status - e.g. fill price for command) 2. what is the traget server for the trading APIs - do they send command to Sierra's server which will then route the command my broker's server, or the command is sent directly to the broker's server ? tnx |
[2017-01-23 09:34:35] |
1. Refer to: Automated Trading From an Advanced Custom Study 2. This depends upon the particular Trading service being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-23 16:00:35] |
> This depends upon the particular Trading service being used. i see ... - how does it work for Interactive Brokers ? - how does it work for FXCM ? |
[2017-01-23 17:41:57] |
In the case of Interactive Brokers the orders go directly to Interactive brokers. In the case of FXCM the orders go through a Sierra Chart server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
