Date/Time: Sun, 12 Jan 2025 00:43:18 +0000
importing study variable
View Count: 781
[2017-01-22 23:29:57] |
pierre94250 - Posts: 5 |
Hi, I'm using a number bar chart in tick range with an automated trading spreadsheet study and a bar chart with minute bar with stochastic study. Is it possible to import the stochastic variables from the bar chart into the spreadsheet of my number bar chart. Sorry if this is simple but I've been searching for hours and didn't find the way. Pierre. |
[2017-01-22 23:51:48] |
Refer to this study here: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-23 11:25:17] |
cool the one that I missed I thougt that finally I found something that's not possible to do but I was wrong :D
