Date/Time: Sun, 12 Jan 2025 00:54:48 +0000
Chart Changed Completely over weekend
View Count: 724
[2017-01-22 22:14:39]
User15414 - Posts: 20
Fortunately I have screen caps of this. On one chart the price doesn't even come close to a level over the weekend it shows huge dip. Pictures below.
image2017-01-21_12-09-42.png / V - Attached On 2017-01-22 22:14:17 UTC - Size: 55.28 KB - 236 views
image2017-01-22_14-10-04.png / V - Attached On 2017-01-22 22:14:26 UTC - Size: 43.92 KB - 255 views
[2017-01-22 22:47:30]
This is a missing data issue. Follow through the instructions here:
If that does not solve it, then it must be a Session Times issue. In this case follow the instructions here:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Incorrect Chart and Session Times Settings
[2017-01-22 23:44:42]
When I run Global settings>> set system time I get a display box that says I'm getting windows error 1314 so maybe that is the problem.
[2017-01-22 23:50:50]
No, that is not going to be the issue.
Is the data still missing in the chart?
[2017-01-23 00:11:27]
No it's complete I'm just trying to figure this out so I'm not looking at a fake chart. I did have
chart settings>> advanced features>> use global time zone and in global settings >> data trade services
I had Los angeles time zone. Don't know if this makes a difference.
[2017-01-23 00:45:24]
It might make a difference based upon how the Session Times are set.
But we do not think this is the cause of the problem.
Date Time Of Last Edit: 2017-01-23 00:45:43
