Date/Time: Sun, 12 Jan 2025 00:50:23 +0000
hello,the candle is wrong ,please check it .
View Count: 714
[2017-01-22 03:57:27]
User166767 - Posts: 32
I compare with candle chart ,and find the candle is wrong ,please see the screenshot in the annex.please check it .it is easy to find the mistake ,I have surrounded in the red circle .
imageQQ截图20170121214954.png / V - Attached On 2017-01-22 03:56:55 UTC - Size: 156.03 KB - 217 views
imageQQ截图20170121215306.png / V - Attached On 2017-01-22 03:57:18 UTC - Size: 108.28 KB - 209 views
[2017-01-22 09:11:12]
This is the last time we are going to answer this question. We cannot help with this other than to recommend that you use the Sierra Chart Exchange Data Feed:
If you do not want to use this data feed, then do not ask us any further questions about this.
Date Time Of Last Edit: 2017-01-22 09:11:38
