Date/Time: Sun, 12 Jan 2025 00:50:23 +0000
Rithmic historical intraday data with service package 5
View Count: 843
[2017-01-21 12:26:35]
nosast2 - Posts: 73
I am with Rithmic and have a direct account for Sierra Chart with service package 5, so the historical intraday data should be included. My problem is that when I can't connect to Rithmics datafeed, e.g. on weekends, I'm not able to download the data from the last couple of days.
How can intraday data be downloaded without Rithmics server?
The symbols I'm looking for are YMH7-CBOT and ESH7-CME.
Thanks in advance
Norman
[2017-01-22 09:06:34]
We tested this and all you need to do is just right click on the chart somewhere near the end of the chart and select Delete and Download Data to start the data download.
You can also consider using CTS which has an always available connection:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel
[2017-01-22 19:20:26]
nosast2 - Posts: 73
Thanks! Your solution worked and I was able to download the missing data. Just needed to get a hint to this "Delete and Download Data".
