Date/Time: Sun, 12 Jan 2025 00:58:18 +0000
SC startup
View Count: 1149
[2017-01-20 13:26:28] |
User57210 - Posts: 121 |
Hi guys, I've been using the same chartbook for several years. Lately (past couple weeks) I've noticed much longer than normal startup time. I've noticed particularly odd behavior around the historical data based charts loading - usually they're lightning fast while the longer intraday charts take longest. Thanks in advance, Merritt PS - I trade mostly crude oil. Each month when it rolls, I have to adjust every single line on my chart for the back-adjustment. Feature request to improve that if possible. Cheers. |
[2017-01-20 17:43:10] |
For this kind of problem refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often We recommend starting off with opening one new chart and seeing if you notice any problem with that. And gradually make modifications to it until it matches an existing chart to see what is causing the problem. PS - I trade mostly crude oil. Each month when it rolls, I have to adjust every single line on my chart for the back-adjustment. Feature request to improve that if possible. Cheers. Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-20 17:43:37
