Date/Time: Sun, 12 Jan 2025 00:48:55 +0000
How to save/share a custom study so it's encrypted?
View Count: 1023
[2017-01-20 06:39:27]
User873998 - Posts: 11
Once I've created a custom study in sierra chart, how do I then save it so I can share it with others while keeping the Intellectual Property of the study safe/protected from others being able to view how it's calibrated?
For instance, on my charts there were some pre-loaded indicators. When I go into studies to look at what the custom indicators are comprised of they all say: ID:1 ID:2 ID:3...and so on. So as to protect the intellectual property of each indicator. I would like to be able to do the same, but am unaware how. (See Attached)
I have gone in and compiled a custom indicator for myself with specific settings, and would have had others request it. I would like to share it, but be able to do so while protecting the intellectual property of how it's configured.
Please advise :)
Thanks!
imageCustom Study Encrypted.PNG / V - Attached On 2017-01-20 06:38:37 UTC - Size: 37.26 KB - 248 views
[2017-01-20 07:27:25]
How will the study be created? Using ACSIL or would it be a built-in study?
[2017-01-20 08:11:00]
It's a combination of built-in studies with specific configurations.
[2017-01-20 09:54:01]
In this case, the best thing to do is to password protect it. Here are instructions:
Chart Studies: Password Protecting Studies
[2017-01-20 14:59:38]
Thank you so much for the prompt help and support! Worked great!
