Date/Time: Sun, 19 May 2024 06:51:49 +0000
SierraChart.exe': Loaded 'C:\SierraChart\SierraChart.exe', Cannot find or open the PDB
View Count: 1139
[2017-01-19 16:44:17] |
b3cker - Posts: 34 |
Hello, I am getting a warning during the debug session. SierraChart.exe': Loaded 'C:\SierraChart\SierraChart.exe', Cannot find or open the PDB file Thank You |
[2017-01-19 17:42:00] |
This is normal and expected. Disregard this.
[2019-11-24 13:55:08] |
User910687 - Posts: 1 |
When I installed the Current Version, all my Custom Studies are gone. They were all developed under 32-bit. It happened to me before but I was able to open Sierrachart.exe, 32-bit, however, currently the only option on my C drive is 64-bit. Please assist.
[2019-11-24 15:05:24] |
The 32-bit version of Sierra Chart is discontinued. Contact the developer of the custom studies and have them recompile them as 64-bit. This is very easy for them to do. We can help if necessary. It does not require any code changes. If code changes are required it is only because the code has not been recompiled in a while and there are probably just small renaming changes needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-26 03:46:27] |
User994685 - Posts: 2 |
Thank you for your response. I have reached out to the developer, however, he has not responded. I have 30 custom studies needed to be recompiled. Please, if you could walk me through it, I can do most of it.
[2019-11-26 04:36:47] |
Do you have the CPP files? These are the source code files with a CPP file extension.
[2019-11-27 03:12:09] |
User989487 - Posts: 5 |
No, I don't have the CPP files.
[2019-11-27 04:31:34] |
This question was meant for the user at post #5 (Sikatna Traders).
