Date/Time: Sun, 12 Jan 2025 00:47:21 +0000
How to make current style into study?
View Count: 1022
[2017-01-19 04:01:13]
User701247 - Posts: 117
Please see attached image for details, I would like to know on how to make current style into study.
Does anyone have any suggestions?
Thanks in advance for any suggestion
imageSierra.png / V - Attached On 2017-01-19 04:00:25 UTC - Size: 130.13 KB - 256 views
[2017-01-19 04:15:39]
This is something that does not make sense to do and is not supported in the way that you are looking for.
[2017-01-19 04:48:24]
If I set specific style on ES, and would like to apply the same style on other market.
Do you have any suggestions on what I can do without applying the same style manually into different market?
Thank you very much for any suggestions :>
[2017-01-19 09:22:32]
You can use the Study Collection feature:
https://www.sierrachart.com/index.php?page=doc/StudyCollections.html#Create
And save it as a single study.
[2017-01-19 22:38:05]
When I create Study Collection - Number Bar Testing (Please see Study Collection image), and apply them into new symbol (Please see AUD image).
The detailed format of setting cannot be applied, such as background color, font size, ...
If I would like to apply those setting into any new symbol as default, do you have any suggestions on how to do it?
Thanks, to everyone very much for any suggestions
imageStudy Collection.png / V - Attached On 2017-01-19 22:37:06 UTC - Size: 243.93 KB - 240 views
imageAUD.png / V - Attached On 2017-01-19 22:37:12 UTC - Size: 85.22 KB - 243 views
[2017-01-20 03:06:15]
The background color and font size of a chart is set through the Global Graphics Settings:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html
Make sure the chart is set to use the global graphics settings as explained.
Date Time Of Last Edit: 2017-01-20 03:06:27
[2017-01-20 20:04:03]
I would like to know on where to set the width, scale and font size for each bar on Global Setting, as shown on attached image, so when I open a new chart, the default setting would be applied.
Furthermore, I would like to know on how to show the price level based on the mouse cursor's location.
Do you have any suggestions?
Date Time Of Last Edit: 2017-01-21 00:55:18
imageSetting.png / V - Attached On 2017-01-20 20:02:49 UTC - Size: 62.36 KB - 232 views
[2017-01-23 18:03:46]
Refer to the Graphics Settings page:
For setting the chart scale, refer to:
http://www.sierrachart.com/index.php?page=doc/Scaling.html
Refer to:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues
Date Time Of Last Edit: 2017-01-23 18:04:10
