Date/Time: Sat, 11 Jan 2025 22:53:20 +0000
chart dom ?
View Count: 653
[2017-01-19 01:49:59] |
zippyzip - Posts: 293 |
i have one main chart dom that i use but i want to add some stacking and pulling to another one for orderflow chart , but when i change one the other one changes , can this be stopped , cant each chart have its own dom features ?
[2017-01-19 02:27:14] |
No, this is not supported but most likely it will be later in the year.
