Date/Time: Sat, 11 Jan 2025 22:58:38 +0000
Alerts
View Count: 721
[2017-01-18 16:49:37] |
User54459 - Posts: 7 |
I use the bar difference indicator from studies. Is it possible to set up a alert where the bar would change a different color. Example: If bar hits 5 pts it changes color Thanks so much, Ken |
[2017-01-18 17:46:34] |
Yes. Use this study: https://www.sierrachart.com/index.php?page=doc/ColorBarBasedOnAlertCondition.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
