Date/Time: Sat, 11 Jan 2025 22:59:46 +0000
Volume Clusters
View Count: 2475
[2017-01-18 14:36:25] |
User104854 - Posts: 457 |
Hi. I was watching a webinar yesterday and the attached chart came up that is used on Sierra Chart. I took a screen shot of it. It looks like a Bookmap chart. I am already familiar with the Market Depth Profile indicator but this also has volume clusters on it. Can you tell me which indicator to use for the volume clusters? Thank you.
[2017-01-18 17:51:11] |
Not sure exactly what you mean by "volume clusters". But if you are referring to the Volume by Price study, here is the documentation for that: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
