Date/Time: Thu, 19 Sep 2024 01:06:11 +0000
P/L on chart
View Count: 1580
[2013-08-07 12:42:47] |
User56044 - Posts: 62 |
I am getting a line on my chart that says "P/L: 0.46/-1@105.67" I know it shows my position but I have no idea how it got there! How do I remove it? |
PL on Chart.png / V - Attached On 2013-08-07 12:40:51 UTC - Size: 8.23 KB - 518 views |
[2013-08-07 16:40:31] |
Is Trade >> Trade Simulation Mode On enabled?
[2013-08-07 22:18:29] |
No. Trade simulation is NOT enabled. |
[2013-08-07 22:32:29] |
Update to the latest release of Sierra Chart by selecting Help >> Download Prerelease. You are also going to need TWS version 9392 to connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
