Date/Time: Sat, 11 Jan 2025 22:59:27 +0000
visual C++ compiler
View Count: 1103
[2017-01-18 12:41:35] |
User972895 - Posts: 1 |
Trying to get the link to the windows C++ compler download...link not working
[2017-01-18 17:43:16] |
You really should use the Remote Build command instead. We see no problem when using this command: Analysis >> Build Custom Studies DLL >> Install Compiler. It does link to the correct Microsoft file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
