Date/Time: Sat, 11 Jan 2025 23:01:03 +0000
rithmic
View Count: 943
[2017-01-17 22:11:39]
JP1 - Posts: 9
I cant seem to connect to rithmic please help! every time I try, the box in the top left turns yellow, like its busy then keeps flashing connected...disconnected...waitng to reconnect over and over
Date Time Of Last Edit: 2017-01-17 22:24:58
[2017-01-17 22:13:14]
Provide a copy of the Message Log by following these instructions:
[2017-01-17 22:26:57]
JP1 - Posts: 9
I have seen that message log before but I am not getting one at this point. I can view charts if I go to other dts settings but I really need to get rithmic functioning
[2017-01-17 22:30:47]
JP1 - Posts: 9
is it possible that it is because I don't have trading software that works with it, or will sierrachart work independently and it is just not responding on my computer?
[2017-01-17 22:34:23]
JP1 - Posts: 9
oops got it here....
Reading Internal Order ID file. | 2017-01-17 22:10:26
Reading Trade Orders file. | 2017-01-17 22:10:26
Reading Trade Positions file. | 2017-01-17 22:10:26
Software version: 1506 | 2017-01-17 22:10:26
Uses New Spreadsheets | 2017-01-17 22:10:26
Usage end date: 2017-01-31 | 2017-01-17 22:10:26
Enabled for: Advanced Features. | 2017-01-17 22:10:26
Enabled for: Advanced Features 2. | 2017-01-17 22:10:26
Enabled for: Sierra Chart Historical Data Service. | 2017-01-17 22:10:26
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-01-17 22:10:26
Current selected Data/Trading service: Rithmic Trading | 2017-01-17 22:10:26
Chart Update Interval: 500 | 2017-01-17 22:10:26
Time Zone: +00:00:00 (UTC+00) | 2017-01-17 22:10:26
2017-01-17 14:10:30 Local computer time | 2017-01-17 22:10:26
2017-01-17 22:10:30 Local computer time in UTC | 2017-01-17 22:10:26
2017-01-17 22:10:30 Local computer time in SC Time Zone | 2017-01-17 22:10:26
2017-01-17 22:10:17 Server time in UTC | 2017-01-17 22:10:26
Local computer UTC time and Server UTC time difference: 12 seconds. | 2017-01-17 22:10:26
Program path: C:\SierraChart\ | 2017-01-17 22:10:26
Data Files path: C:\SierraChart\Data\ | 2017-01-17 22:10:26
OS Version Number: 6.2 | 2017-01-17 22:10:26
Locale Setting: C | 2017-01-17 22:10:26
Rithmic Trading | Port for executable: 52350 | 2017-01-17 22:32:43
Listening socket (1116), port 52350 | Closed. | 2017-01-17 22:32:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-17 22:32:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52350 | 2017-01-17 22:32:45
DTC Client (76) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-17 22:32:46
DTC Client (76) | Shutdown and closed. | 2017-01-17 22:32:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-17 22:32:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-17 22:32:46
Rithmic Trading | Disconnected. | 2017-01-17 22:32:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-17 22:32:46
Rithmic Trading | Port for executable: 52353 | 2017-01-17 22:32:48
Listening socket (1580), port 52353 | Closed. | 2017-01-17 22:32:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-17 22:32:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52353 | 2017-01-17 22:32:50
DTC Client (77) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-17 22:32:51
DTC Client (77) | Shutdown and closed. | 2017-01-17 22:32:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-17 22:32:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-17 22:32:51
Rithmic Trading | Disconnected. | 2017-01-17 22:32:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-17 22:32:51
Rithmic Trading | Port for executable: 52355 | 2017-01-17 22:32:53
Listening socket (1580), port 52355 | Closed. | 2017-01-17 22:32:53
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-17 22:32:53
Service is currently connecting. | 2017-01-17 22:32:54 *
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52355 | 2017-01-17 22:32:55
DTC Client (78) | Connected. | 2017-01-17 22:32:55
Rithmic Trading | Connected to server. | 2017-01-17 22:32:55
Rithmic Trading | Sending Encoding Request to server | 2017-01-17 22:32:55
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-01-17 22:32:55
Rithmic Trading | Sending logon request message. | 2017-01-17 22:32:55
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-01-17 22:32:55
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-01-17 22:32:55
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2017-01-17 22:32:55
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-01-17 22:32:56
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-01-17 22:32:56
Rithmic Trading | Received logon response. | 2017-01-17 22:32:56
Rithmic Trading | Server Name: DTC Bridge. | 2017-01-17 22:32:56
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-01-17 22:32:56
Rithmic Trading | Logon error received from server | 2017-01-17 22:32:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-17 22:32:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-17 22:32:56
DTC Client (78) | Shutdown and closed. | 2017-01-17 22:32:56
Rithmic Trading | Disconnected. | 2017-01-17 22:32:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-17 22:32:56
Rithmic Trading | Port for executable: 52367 | 2017-01-17 22:32:58
Listening socket (1364), port 52367 | Closed. | 2017-01-17 22:32:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-17 22:32:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52367 | 2017-01-17 22:33:00
DTC Client (79) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-17 22:33:01
DTC Client (79) | Shutdown and closed. | 2017-01-17 22:33:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-17 22:33:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-17 22:33:01
Rithmic Trading | Disconnected. | 2017-01-17 22:33:01
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-17 22:33:01
Rithmic Trading | Port for executable: 52375 | 2017-01-17 22:33:03
Listening socket (952), port 52375 | Closed. | 2017-01-17 22:33:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-01-17 22:33:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52375 | 2017-01-17 22:33:05
DTC Client (80) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-17 22:33:06
DTC Client (80) | Shutdown and closed. | 2017-01-17 22:33:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-17 22:33:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-17 22:33:06
Rithmic Trading | Disconnected. | 2017-01-17 22:33:06
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-17 22:33:06
Date Time Of Last Edit: 2017-01-17 22:54:42
[2017-01-17 22:55:49]
This is the reason for the problem:
Follow through the instructions here for this:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
