Date/Time: Sat, 11 Jan 2025 22:44:15 +0000
High/Low display of a period
View Count: 1741
[2017-01-17 20:09:52]
crossiman - Posts: 29
Is there a possibility to get the High/Low of a certain number of bars displayed on a chart (no matter which period) inside SC ? To understand what I mean I added a screenshot.
imagePivotHL.png / V - Attached On 2017-01-17 20:09:06 UTC - Size: 54.46 KB - 335 views
[2017-01-17 21:13:50]
Based on how we understand this, the closest that is available is the Highest High/Lowest Low Over N Bars study:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s54
[2017-01-17 21:47:10]
No, I don't think that you understood correctly. I do mean the display of the values at the extremes of a chart. In my added chart the values at the extremes of the EURUSD (so called Pivot H/L).
[2017-01-17 22:09:45]
Have a look at these studies:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s294 (Period OHLC-Variable Period)
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s239 (Daily OHLC - Single Point)
Date Time Of Last Edit: 2017-01-18 17:54:48
[2017-01-18 12:51:37]
Also with your mentioned studies I cannot recognize any connection with my question. Sorry for that.
I will try to ask in a different way: Is there a possibiliy inside SC to display the prizes at some extreme Highs and Lows of different moments of time automatically ? You can see this once again in the attached screenshot of the EURUSD highlighted by the red frame.
MANY THANKS !
image2017-01-18.png / V - Attached On 2017-01-18 12:48:46 UTC - Size: 127.31 KB - 272 views
[2017-01-18 17:55:49]
No, this is not supported. We have given you studies which are as close as possible to what you are looking for and you might find useful.
Date Time Of Last Edit: 2017-01-18 17:56:56
[2017-01-18 20:18:02]
Sawtooth - Posts: 4148
You might also try the Zigzag study.
Set the 'Display Reversal Price' to Yes
Set the Draw Style of SG1 to Hidden
[2017-01-18 22:11:06]
Wow, tomgilb ! That's very near to what I was searching for. So I additionally tried changing the setting for "Reversal % for Calculation Mode 1" and I got something very similar to what I need. Real great advice. MANY THANKS !!!
