Date/Time: Sat, 11 Jan 2025 22:15:00 +0000
Question about sound files
View Count: 614
[2017-01-17 02:19:41] |
GPST10 - Posts: 139 |
If I delete the sound file - is it wasted or I'm allowed to re-create new one? Asking this because there is no way to test before purchasing. Thanks |
[2017-01-17 03:15:52] |
You can find the sound files here: https://www.sierrachart.com/UserControlPanel.php?page=TextToSpeech Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
