Date/Time: Sat, 11 Jan 2025 22:18:03 +0000
order and position window inquiry
View Count: 648
[2017-01-17 01:20:40] |
User157806 - Posts: 71 |
Have a general question is it possible to see liquidation value within Sierra Charts? I know you can see start of day balance (Cash balance) and I know you can also see realized balance.... (Cash balance + realized intraday P&L) but the customer would like to see liquidation value. Example would be if the customer has open positions and started the day with $10k and is making $2k on the open positions so liquidation value would show $12,000 Johnny... |
[2017-01-17 04:31:25] |
We assume they would be using CQG? We will ask CQG this question.
[2017-01-17 04:32:19] |
Correct CQG thank you.
