Date/Time: Sat, 11 Jan 2025 21:55:39 +0000
Running SC from a Data Storage Drive
View Count: 629
[2017-01-16 19:07:19] |
buylosellhi - Posts: 60 |
Hi, I'm running out of space on my C: drive (mainly due to big .scid files). Is it possible to run SC on a data storage drive ? thanks |
[2017-01-16 20:08:13] |
Yes. Sierra Chart can be run from any drive.
