Date/Time: Sat, 11 Jan 2025 22:20:12 +0000
Daily change (as percent) for spreadsheet
View Count: 1112
[2017-01-16 11:34:16] |
stevenpaul - Posts: 9 |
Hi, Is there a study or some way of listing the daily change (change from yesterday's close) expressed as a percentage, in the spreadsheets? I would like to use that data as part of a my system. Thank you! |
[2017-01-16 19:32:58] |
You could use the Rate of Change-Percentage study with a Length of 1 on a Historical Daily chart and then overlay it by using the Study/Price Overlay study to the destination chart: http://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-16 19:33:21
