Date/Time: Tue, 04 Feb 2025 02:06:09 +0000
Questions about Trading Locked mode
View Count: 2883
[2017-01-16 07:49:20]
ticinotrader - Posts: 401
Hi, I have three questions related to 'Trading Locked' mode:
1. is it possible to lock trading for one chart or one DOM only and not globally? I mean being able to independently enable/lock trading for each of my charts/DOM?
2. is it possible to somehow display on the DOM or chart that trading is locked? I think about something similar to the display of Sim/Live trading.
3. Is there a way to set Sierra to start in 'Trading Locked' mode by default?
Thanks!
[2017-01-16 08:00:53]
1. No.
2. No but we will see if we can put some kind of indicator to indicate this.
3. No.
[2017-01-16 08:07:29]
One additional question:
When there is a detached chart its Trade menu contains the 'Trading Locked' menu item. Is it possible to add this to detached DOMs as well? I mean include the menu item 'Trading Locked' in their Trade menu?
Thanks!
[2017-01-16 08:11:29]
2. This will be added to the next release.
[2017-01-16 08:11:59]
Yes, we did notice this just now and added it.
[2019-04-18 02:25:04]
User745789 - Posts: 356
I'd add a vote for #3.
[2019-04-18 03:43:19]
Post #3 has been implemented a long time ago. You can find that on the Trade menu.
[2019-04-18 03:51:22]
Sorry for taking up your time, but the only reference I see to a startup settings in the Trade menu relates to "Auto Trading". Trade Menu: Disable Auto Trading On Startup (Trade menu)
I do not employ AutoTrade.
I do not see any settings that relate to trade lock beyond the one item that allows me to manually check/uncheck Trade Lock.
[2019-04-18 03:59:05]
Okay, what are you then looking for?
[2019-04-18 04:19:47]
[2019-04-18 18:05:25]
No, this is not supported.
[2019-11-03 21:51:42]
osaga - Posts: 53
SC
Did you ever implement a study that shows on the chart if locked mode is on?
I would like to see the background color change when it is locked.
Is there an acsil function for locking trading?
[2019-11-04 03:11:03]
You can develop a custom study to do what you want.
And refer to this new function:
sc.SetTradingLockState()
And:
ACSIL Interface Members - Variables and Arrays: sc.TradingIsLocked
Date Time Of Last Edit: 2019-11-04 03:14:13
[2019-12-22 09:19:28]
Ackin - Posts: 1865
Status visualization study and other study to set up trading locked ON / OFF mode are available in our forum.
contact link:
