Date/Time: Sat, 11 Jan 2025 22:19:24 +0000
How to customize DOM columns independently
View Count: 727
[2017-01-16 07:43:51] |
ticinotrader - Posts: 397 |
Hi, I have several DOMs open and want to set them differently (DOM Columns), but when I customize one DOM's columns, all the other DOMs change accordingly. Can I somehow change/set the displayed columns for each of my DOMs separately? Thank you. |
[2017-01-16 18:39:07] |
This is not supported.
