Date/Time: Sat, 11 Jan 2025 22:08:09 +0000
order with manual loop
View Count: 717
[2017-01-16 05:19:15]
User103949 - Posts: 78
In your documentation, it mentioned "There are versions of these functions for manual looping, but they are undocumented. The only difference is the ones for manual looping have an Index parameter".
What is this Index parameter for?
[2017-01-16 07:41:54]
The Index parameter specifies the chart bar index that the order entry function is used in relation to.
