Date/Time: Sat, 11 Jan 2025 21:53:09 +0000
bar duration in number bar study on spreadsheet
View Count: 1116
[2017-01-15 22:24:10]
pierre94250 - Posts: 5
I want to use the "bar duration" variable in the spreadsheet system for trading study.
Is it possible to explain the relastionship between the actual value on the spreadsheet and a real time value ?
For example, I can see that "0.00064816" is the value of the bar duration column for a 56 second bar but I don't know how to use that number to make a rule for my trading system.
Thank you !
Pierre.
[2017-01-16 07:44:15]
This is called the serial Date-Time value and is explained in detail here:
Spreadsheet Functions: Serial DateTime Values
There are also spreadsheet functions which work with the serial Date-Time values. They are listed on this page:
[2017-01-16 11:37:54]
thank you
