Date/Time: Sat, 11 Jan 2025 22:50:24 +0000
Numbers Bars Dominant Volume Percent format
View Count: 714
[2017-01-15 18:59:31] |
User50927 - Posts: 91 |
I was wondering if you could please change the format for the "Dominant Side Volume Percent" text option in the Numbers Bars study from a decimal to just and integer. In my opinion, the extra significant figure is unnecessary and cluttering in this type of quick visual analysis and in addition, it increases the bar's footprint. Thank you.
[2017-01-15 19:39:08] |
Yes we can do this.
