Date/Time: Sat, 11 Jan 2025 22:58:26 +0000
SPREADSHEET TRADING
View Count: 699
[2017-01-13 18:05:22] |
Trader&Hunter - Posts: 131 |
I want to test different time frames via my spreadsheet automated study. but if i trade one time frame it and switch to another it takes me out prematurley because the spreadsheet is thinking i changed time frames. how do i run all time frames for statistical purposes?
[2017-01-13 18:41:36] |
Do you mean you want to do back testing? From what we understand, you will want to have a separate chart for each timeframe and then use the Spreadsheet System for Trading study on each of those charts. Each of those studies can refer to the same Spreadsheet and use the same formulas. Refer to: http://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#FormulaSourceSheetNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-13 18:42:28
