Date/Time: Sat, 11 Jan 2025 22:52:47 +0000
Write an alert based on RSI
View Count: 1421
[2017-01-13 17:25:35] |
User1193154 - Posts: 54 |
Hello, please someone could write an alert based on RSI-W and time frame ? I'll paid for it, obviously. Thank's Flavia |
[2017-01-13 18:05:16] |
Tell us what you want and we will let you know about this.
[2017-01-13 20:54:05] |
Thank you, I like to be alerted when RSI Williams (I use it) break down 32 value. I dont understand specific Sierra language, so am unable to write it. Then I'll copy and paste it at all timeframe (level 32 is the same at every timeframe). Best regards. Flavia |
[2017-01-14 09:24:18] |
This is easy. Here is the formula: CROSSFROMABOVE(SG1, 32) Follow through the instructions to use it on the RSI: Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
