Date/Time: Sat, 11 Jan 2025 22:49:47 +0000
Spreadsheet Value Draw Style Off Set
View Count: 633
[2017-01-13 12:56:43] |
User787778 - Posts: 142 |
Can one apply an offset to values when using "Draw Style" of "Value On Low/High" on the actual values?
[2017-01-13 18:10:33] |
No this is not supported when using Spreadsheets. Something like this is only possible with ACSIL.
