Date/Time: Sat, 11 Jan 2025 22:57:41 +0000
Trader Dynamic Index & Alert Triggering Code Validation Request
View Count: 1334
[2017-01-13 12:44:25] |
isa74 - Posts: 54 |
Sir, I have created the Dynamic Trader index indicator using several components inside Sierra : A Study to integrate all the other elements, in this case I have chose the RSI Then I added these elements: * Green line = RSI Price line = 1 SMA 2 (ID34) * Red line = Trade Signal line = 1 SMA 7 (ID35) * Blue lines = Volatility Bands = 2 SMA 35 as Bollinger Bands with a deviation of 1.62 * Yellow line = Market Base Line = 1 SMA 35 If I want to code an alert when the RSI Priceline crosses the Trade Signal Line, should I create one Color Bar Based On Alert Condition with this code ?: =CROSSOVER(ID34.SG1,ID35.SG1) or should I insert this code elsewhere ? I am asking this as it seems not to be very effective at the moment.. If I want to add some conditions for triggering the alert with levels being respected, shall I add a lign after the first one like ? =CROSSOVER(ID34.SG1,ID35.SG1) =AND(ID33.SG1 > 70,ID33.SG1 < 30) ID33 is the indicator RSI that receive all the other elements initially. See attached please. It is a matter of understand how these component can interact one with another with the code. I am a bit lost, i must say...to get to this point. Can you help me ? Thanks : ! Thanks !! |
sc_TDI_components.png / V - Attached On 2017-01-13 12:44:10 UTC - Size: 40.77 KB - 257 views |
[2017-01-13 18:11:16] |
We provide alert programming help for 35 USD per hour.
