Date/Time: Sat, 11 Jan 2025 22:55:10 +0000
Is Sierrachart able to place order on IB for execution?
View Count: 674
[2017-01-13 10:50:27] |
User701247 - Posts: 117 |
I would like to know on whether Sierrachart is able to place order through programming for execution on IB or not. Does anyone have any suggestions? Thanks in advance for any suggestions Date Time Of Last Edit: 2017-01-13 10:51:16
[2017-01-13 17:59:25] |
Live trading is supported when using Interactive Brokers with Sierra Chart. Refer to: http://www.sierrachart.com/index.php?page=doc/Trading.html Also refer to this page here: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-13 18:00:12
