Date/Time: Sat, 11 Jan 2025 22:53:50 +0000
scsf_DynamicMemoryAllocationExample
View Count: 659
[2017-01-12 20:49:39] |
b3cker - Posts: 34 |
How would I determine size of a dynamically allocated array in the title example. (scsf_DynamicMemoryAllocationExample) Thank You |
[2017-01-12 21:30:35] |
The size of the array is specified when it is created and you need to remember that. You can store the size in a static variable or store it in persistent storage: sc.GetPersistentInt() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-12 21:30:57
