Date/Time: Sat, 11 Jan 2025 22:48:47 +0000
Saving Study Collections in v1506
View Count: 1243
[2017-01-12 19:37:16]
Sawtooth - Posts: 4148
When saving a study collection, and checking 'Prompt to Remove Existing Studies', a '+' is added to the file name, and when you use it, it does not prompt, it replaces.
If you manually change it to a '-', it still doesn't prompt, it just replaces.
v1506.
[2017-01-12 21:20:16]
This has been corrected. We are releasing a new revision of 1506 now.
Update by selecting Help >> Download Prerelease.
And refer to the notes here about this change:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php
[2017-01-14 10:21:12]
FFTrader - Posts: 180
Ah, I am using 1506 - problem still not fixed!? Regardless of a "+" or a "-" at the end ... it just replaces. Can we stick to the original "-" please??
Date Time Of Last Edit: 2017-01-14 10:23:33
[2017-01-14 20:39:54]
This has already been resolved. Update Sierra Chart with Help >> Download Prerelease.
The version number did not change.
Date Time Of Last Edit: 2017-01-14 20:40:12
[2017-01-15 00:01:49]
This is still supported. You can still use this.
[2017-01-15 01:50:22]
Okay ... yes the Pre-release version of 1506 works ... I would say the current version of 1506 does not work - still. Now I don't know why it is like that but please investigate but when I changed from the latest version of 1506 to the Pre-release version, it worked. I think if I made a mistake, it would be somewhat honest to assume they are identical after the pre-release date?
Yes, the "-" is still supported with the Prerelease version. Thanks.
Date Time Of Last Edit: 2017-01-15 01:51:12
[2017-01-15 01:54:17]
I am now changing all my "current versions" to "Pre-release versions" despite it is after the pre-release date.
