Date/Time: Sat, 11 Jan 2025 22:57:14 +0000
CQG - WebAPI vs FIX
View Count: 1217
[2017-01-12 16:18:09] |
User104854 - Posts: 457 |
I recently switched brokers to Stage 5 and am using CQG for data. The guy at AMP who I clear through said to use WebAPI and I saw something on your site that recommended the FIX connection. Is there a preference that should be used with Sierra Chart? I don't want to run into problems. Thank you.
[2017-01-12 17:55:53] |
At this point in time there should not be any difference as long as you are running the current version of Sierra Chart. But generally we prefer FIX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
