Date/Time: Sun, 13 Sep 2026 04:25:46 +0000
"Auto-follow" for retracement-drawings
View Count: 1049
| [2017-01-12 14:21:35] |
| BrMa - Posts: 80 |
Dear ladies and gentlemen, I'm looking for the following functionality but could not find it - is something like this possible in SierraChart? Imagine you have a low in the market and you are drawing a retracement between the low and the actual price (which is higher). After the retracement was drawn, the price is increasing further - is there a possibility to tell the retracement-tool it should automatically adapt itself with the highest price between it's starting point and the actual point in time? And of course the other way round if it is a retracement on decreasing prices... Reason for the question: I'm aware this can be easily done manually, but if it comes to highs and lows in larger timeframes this becomes a lot of work to do if you wanna keep your charts updated... especially if you're trading more than one product... Thanks a lot in advance! Regards, Markus |
| [2017-01-12 20:24:47] |
No, this is not available but there is this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s169 (Auto Retracement/Projection) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-12 20:25:02
