Date/Time: Sat, 11 Jan 2025 22:53:23 +0000
Alert for BB & Moving Average
View Count: 1884
[2017-01-12 11:32:39] |
isa74 - Posts: 54 |
Sir, I would like to know ifthese code are correct as I do want to create an alert that triggers when the candle touch the bottom and/or the top bollinger band please ? =CROSSOVER(SG1, C) =CROSSOVER(SG3, C) For a candle crossing a moving average curve, it would be ? =CROSSOVER(SG1, C) SG1 is the moving average and C ? C is the asset value ? Thanks for your precisions. |
[2017-01-12 22:38:57] |
Response is still pending.
[2017-01-13 05:40:57] |
I would like to know ifthese code are correct as I do want to create an alert that triggers when the candle touch the bottom and/or the top bollinger band please ? =CROSSOVER(SG1, C) =CROSSOVER(SG3, C) Study/Chart Alerts And Scanning: Alert Formula Examples This is a new example we just added today. C is the closing price of a chart bar. Refer to: Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-13 05:41:21
[2017-01-13 13:47:02] |
isa74 - Posts: 54 |
Sir, Sir, a Bollinger Band can be crossed from above and from below both at the top and bottom band. To trigger an alert for each of these cases (4 in total), I should insert this code in 2 Color Bar Based on Alert Condition ? If the BB are ID:8 Top Band: SG1 Bottom Band: SG3 Color Bar Based on Alert Condition n°1 =CROSSFROMBELOW(ID8.SG1,ID8.SG3) Color Bar Based on Alert Condition n°2 =CROSSFROMABOVE(ID8.SG1,ID8.SG3) This is just a request of confirmation. Thanks a lot for your precisions ! |
[2017-01-13 18:23:46] |
We provide alert programming help for 35 USD per hour.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-13 18:24:01
