Date/Time: Sat, 11 Jan 2025 22:55:37 +0000
Order chartbooks in an instance
View Count: 668
[2017-01-12 11:22:37] |
User252419 - Posts: 235 |
How to order chartbooks in an instance. I know how to order charts in a chartbook, but not how to order chartbooks in an instance. Thank you |
[2017-01-12 17:55:01] |
The only way this can be controlled is according to the order in which the Chartbooks are actually opened. There is no other way to change the order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
