Date/Time: Sat, 11 Jan 2025 22:50:08 +0000
Scale settings - Keep last bar in view
View Count: 1054
[2017-01-12 02:01:51] |
User19165 - Posts: 346 |
Hello, I'm running into a problem trying to use a constant range scale and keep last bar in view. When I right click on the scale, the "Interactive scale range" is checked and "Scale range: constant range" is also checked - that is all. Attached is my scale settings window configuration. What tends to happen is this only keeps the last bar in view some of the time, other times the last bar just runs off the edge of the chart. This becomes really tedious constantly having to adjust 6 charts on various timeframes throughout the day. Please help. With kind regards, MK |
MK-2017-01-12_150101.png / V - Attached On 2017-01-12 02:01:21 UTC - Size: 17.64 KB - 271 views |
[2017-01-12 04:42:49] |
The description here for the setting explains why you see what you do: http://www.sierrachart.com/index.php?page=doc/Scaling.html#ConstRangeKeepLastBarInView And what to do to solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-12 06:33:43] |
I have read that before. That only applies to when "Interactive Scale Move" is checked, right? As I had initially stated, I have "Interactive Scale Range" checked.
Date Time Of Last Edit: 2017-01-12 06:34:10
[2017-01-12 06:54:04] |
No, that is not correct. Reset the scales with Chart >> Reset Scales. As long as you do not make any scaling adjustments, and you do not notice a further problem, it confirms the issue was that the scale was adjusted from the default. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-12 06:54:31
