Date/Time: Sat, 11 Jan 2025 19:47:13 +0000
symbol missing in alert manager/alert log
View Count: 1062
[2017-01-11 15:19:58] |
User170575 - Posts: 221 |
Good morning, I am missing the ticker in the Alert Manager--how could I re-enable this? Fill attached---and Many thx! Cy |
symbol missing.jpg / V - Attached On 2017-01-11 15:19:39 UTC - Size: 314.01 KB - 225 views |
[2017-01-11 17:59:57] |
In this particular case, the name of the custom study is shown which is acting as the main price graph. The study name itself will have to be modified to contain the symbol. That is something you need to do if you created the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-11 18:00:09
