Date/Time: Sat, 11 Jan 2025 22:42:24 +0000
Font size adjustment
View Count: 7093
[2017-01-10 15:04:40]
SY Tong - Posts: 28
I recently started to use a new computer, Microsoft Surface running on Windows 10. I have a big problem with the font size of the Sierra Charts on this computer, it's so small and impossible to read (esp on the X and Y axis). I tried adjusting the resolution of the computer but it doesn't change the font size in Sierra at all. Please help.
See the attached screen cap.
Thank you,
Carolina
Private File
[2017-01-10 15:08:38]
SC Developer - David - Posts: 660
Refer to:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#Fonts
Date Time Of Last Edit: 2017-01-10 18:33:10
[2017-01-10 15:36:40]
SY Tong - Posts: 28
Thanks David for you prompt reply.
I tried all the options under Global Settings > Graphics Settings - Global > Chart Text > Fonts. However, none of those can change the font size of the:
1. X axis
2. Y axis and
3. those numbers on the candle sticks.
Please give me specific instructions for these items, much appreciate it.
Thanks,
Carolina
[2017-01-10 15:49:47]
Increasing font for [Global Settings >> Graphics Settings - Global >> Fonts tab >> Chart Text] should increase font for all items mentioned by you.
[2017-01-10 18:32:21]
Refer to:
[2017-01-11 06:44:07]
SY Tong - Posts: 28
As mentioned in my last email, it didn't work. I tried again after receiving your reply, still doesn't change those font size...
Please really need help here!
Regards
[2017-01-11 07:47:43]
Read through the Introduction section here to understand that there are two different Graphics Settings windows:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#Introduction
You need to use the correct one.
[2017-01-11 08:17:49]
Do let us know if you need more help.
[2017-01-12 02:47:47]
SY Tong - Posts: 28
I didn't realise there are 2 types of graphic settings. now I manage to adjust the font now finally.
Thanks!
Regards,
Carolina
