Date/Time: Sat, 11 Jan 2025 19:59:07 +0000
My depth of market in DOM disappeared
View Count: 713
[2017-01-10 12:40:49] |
User252419 - Posts: 235 |
I don't see orders in ask or bid. Neither these background percentage colours as in the picture. Thank you (Message log removed) Date Time Of Last Edit: 2017-01-10 18:43:50
sierradom.png / V - Attached On 2017-01-10 12:40:16 UTC - Size: 9.99 KB - 213 views |
[2017-01-10 13:02:15] |
This is what I see now in the picture attached. And I want to see exactly the same as in the last picture sent. Thank you |
[2017-01-10 18:46:42] |
You need to add the Bid/Ask Size columns. This is documented here: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-10 20:00:15] |
Now I don't know how to overlay buy column with bid/size column. This is what I see now: thank u |
OVERLAY.PNG / V - Attached On 2017-01-10 19:59:55 UTC - Size: 21.35 KB - 212 views |
[2017-01-10 22:59:52] |
As the documentation explains you need to add these columns: Bid Size/Buy Column Ask Size/Buy Column Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
