Date/Time: Sat, 11 Jan 2025 19:55:41 +0000
symbol format for options on futures on Eurex
View Count: 775
[2017-01-10 10:05:12] |
User12089 - Posts: 361 |
what is the Symbol format for Options on Futures traded on Eurex (e.g. Options on EURO STOXX 50) - the following link is relevant only for Options on Futures traded on Globex http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#FuturesOption |
[2017-01-10 17:52:05] |
The format is documented in the link that you gave: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#FuturesOption The format given applies to all futures markets. Not just a particular exchange. For further help contact Interactive Brokers in order to determine the different fields of the Contract: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#ContactingIBForSymbolSpecifications Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
