Date/Time: Sat, 11 Jan 2025 19:54:14 +0000
J6 scale settings
View Count: 606
[2017-01-10 06:16:33] |
User376746 - Posts: 63 |
hello, every currencies futures charts, get the scale setted to "automatic", then it's all right BUT NOT for the J6 symbol (Japanese yen). For J6 the scale says (actually for example): price= 0.86750, but the correct price is: 0.0086750. I'm not able to correct this "error", how can I? thank you, user: lenato69 |
[2017-01-10 18:51:13] |
How this is formatted depends upon how every Data service quotes it. In the case of the SC Data - All Services, this is the format. You can adjust this by changing the Real-time and Historical Price Multipliers: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#RealTimePriceMultiplier Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
