Date/Time: Sat, 11 Jan 2025 19:55:54 +0000
Global Loss Management: Position being flattened after expected time
View Count: 731
[2017-01-10 05:04:18] |
jackbravo - Posts: 69 |
Hi, My position was flattened today immediately after I put on a trade at 2300 CST. I set the Global profit/loss management to close out any positions at 1509:50 CST, so I'm not sure why it's closing my position. Thanks for any help. Date Time Of Last Edit: 2017-01-10 05:05:26
Private File |
[2017-01-10 06:41:27] |
We have to think about this and implement completely safe logic for this. Had you made any changes to the Flatten Positions at Set Time >> Flatten Time setting around when this happened? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-10 06:50:53] |
I did not. I had previous issues with the same sort of thing, but everything was fine after I updated (a prior support thread). I also traded last night without an issue, though it was after midnight and before the 1509 close, so I'm not sure if that matters. Also, I started a second instance of SC (pointed to a different broker), with the same parameters set, and it did not close out the trade. In the second instance of SC, I made no trades yesterday after midnight (while I did so in the first instance of SC, as described above). Date Time Of Last Edit: 2017-01-10 06:55:27
[2017-01-10 07:17:27] |
OK, we are working on this now. We are re-implementing the logic of this to make sure something that this cannot possibly happen. Not sure why did happen though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
